586,441 active members*
3,756 visitors online*
Results 1 to 1 of 1
    Locating a pin to install auto z probe
    I purchased an inexpensive z probe plate on amazon. I need to know where to hook up the wires into my control board. One comes from the plate, the other from the alligator clip(ground)
    My machine is an Industrial CNC Artisan408. When I pulled the board out, I was expecting to find a row of 15 pins, and just count to get location using Estop wire as reference. It is in the slot labeled E. I assume the ones next to it are the limiting switches H=high, L=low.
    Using Mach3 Software.
    Thank you.
    Chuck.
  1. MAZAK ST35 tool locating Pin Replacement
    By Lance2793q in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-04-2018, 04:02 AM
  2. Collet locating pin failure: spindle disassembly
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 12-08-2016, 05:08 PM
  3. Trying to find out what this locating pin/clamp is
    By bweidlein in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-25-2013, 09:55 PM
  4. Locating MFin pin - Fanuc OM
    By charger19690 in forum Fanuc
    Last Post: 11-07-2011, 02:00 AM
  5. r-8 locating pin broke
    By jarr88 in forum Benchtop Machines
    Last Post: 08-27-2007, 01:32 AM
