586,115 active members*
3,429 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Genos L250 with ATS 3J Collet Chuck
    Jan 2009
    55
    Wondering if anybody is running an ATS 3J collet chuck on a Genos L250e? I need to make a draw tube adapter to change it over from my Cadet LNC-8.
    I’d really appreciate if some could measure, or has the dimensions for one.
    Jun 2015
    4154
    Re: Genos L250 with ATS 3J Collet Chuck
    hy voss from time to time i take chucks down, and drawtube, etc, to clean
    thus i can easy measure, and have values for 2 lb lathes, but i don't know if those are relevant to you, as you use a coolet chuck
    if possible, take down chuck/coller, measure travel in respect to spindle nose, then mount chuck back, check travel with chuck, etc ... then adapt
    how may i help you ? kindly
    Jan 2009
    55
    Quote Originally Posted by deadlykitten View Post
    I can measure the tube when the new machine arrives. I was just hoping that somebody was currently running the Genos L250 and the ATS 3J...and I could copy the draw tube adapter.
    Thanks though.
    Jun 2015
    4154
    if the new machine is similar to old one, or the allready existing one you get it new, then there is a chance to request techincal drawing sheet of kitagawa preparation, through your okuma dealer, or direct to your kitagawa rep
    i did that a few years ago if configuration is standard from a few years allready, then what you need may be available quick, as arhive
  1. Okuma Genos L250 Alarm help
    By Toby in forum Okuma
    Last Post: 07-07-2016, 12:46 AM
  2. Joint for ATS chuck
    By maximusek in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2011, 06:44 PM
