This question is two-sided. Regarding stripping failure the operating manual says:
"Confirm that the punch is not stuck in the worksheet. The operation can then be resumed by pressing the "START" button. If the punch is stuck in the worksheet, dismount the punch and die and check them".
1) So when I get this error I take a look at the punch and I´ve seen two different cases: best case the punch is up so I just press "START" and continue. The second case the punch is down, close to the sheet, so I do not know for sure if it´s stuck or not. In this case I have pressed "Reset" and the punch goes up, so it was not actually stuck , but the program gets "disrupted" (to describe the problem somehow) and I get an error if I press start (I seem to recall T-CODE not found, I am not quite sure).
So regarding this, how do I check whether the punch is actually stuck or not ? Can I use the RAM position switch to the top dead center position to check this ?
2) I have not met this scenario yet, but I guess sooner or later I might... What happens when the punch is actually stuck or broken and the sheet is warped. Will I need to get in there with hammer in hand until I can release the sheet ?
