So I have had my machine running with a Gecko g540 + ESS + Mach4 settup for a while now.
The last ting I did to ensure stability, was to get a CAT6 isolated ethernet cable, with isolated adaptors, I have an isolated cable for the spindel signal, and I made a closed aluminum compartment for the ESS. I think this improved stability quite a bit, but you should be able to trust a CNC controller more then that.
Still doing a large v-carving project, I had the 0 origin jumping, and I think it had to do with the screen saver.
Now I set the screen saver and sleep mode to Never. I have done so in only one way in windows 7.
It stil feels like I can never fully trust my system to complete a large job without errors, but hopefully this is it, and the machine will run in stable maner from now.
Is there anything else I should think of to ensure stability?
Best regards, and thanx for any additional tips.
