Good morning
I am setting up a VFD YL620 ( knock off brand and original, jumper is set correct ( next to the terminal strip) to Mach 3 USB cable connected. On/off works fine. Due to the vagueness of Mach3 manual I am not sure of the ports AND pin #'s in the Spindle set up screen ( I have seen many configurations posted). Also am I right in assuming the electrical connections are to VSO and the Gnd terminal next to it. And am i I right in assuming the output should be 0-10V NOT PWM.
