586,449 active members*
3,244 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21M - MV40E DRO Updating but no movement
    Nov 2008
    26
    Question Fanuc 21M - MV40E DRO Updating but no movement
    Hi All,
    I have a customer who has an old Mori MV-40e which uses a variant of the Fanuc 21-m. Any axis connected to the Servo 3(Z Axis) port on the A16B-2201-0721 card results in the DRO changing when jogging or running G-Code but no movement. I would have expected a following alarm or some other type of alarm but I am not. The machine seems perfectly happy with what it is seeing. I recommended replacing the A16B-2201-0721 but would like to see what you guys thought before doing so. I'm not a huge fan of just firing the parts cannon.
    I have confirmed the issue is not with the Servo Drive by swapping the connections with the Servo 2 port and the Z-Axis works fine.
    Apr 2012
    85
    Re: Fanuc 21M - MV40E DRO Updating but no movement
    Leet,
    Have you checked interface diagnostic G108.2?
    Nov 2008
    26
    I have not, can you provide a little more info G108.2 are you talking about in the ladder?
    I did try replacing the A20B-2901-0700 (Servo interface module) and A20B–2901–0340 (Servo control module). It had no effect.
    Nov 2008
    26
    Found it,
    Nov 2008
    26
    Quote Originally Posted by kingofl337 View Post
    Found it,
    So the final solution ended being the Z was disabled.
    The Machine a Mori MV-40E doesn’t have hardware disable switches on the panel so the Z is on a custom screen. The customer swore he didn’t touch it and didn’t even know it existed.
    The feature allows the machine to not send servo commands but allow the dro to update. The value of PRM Status G108 shows what axis is disabled. 1=Disabled.
  1. Mori Seiki MV40E with fanuc 21i control
    By paulk333 in forum Fanuc
    Last Post: 05-09-2022, 12:38 PM
  2. DRO not showing rotary table movement
    By gt40man in forum Tormach Personal CNC Mill
    Last Post: 05-30-2013, 03:48 AM
  3. NO DRO movement when x is manually jogged
    By p-j in forum Mach Plasma / Laser
    Last Post: 02-05-2013, 04:36 AM
  4. DRO's not reporting the correct movement distance
    By mikemaat in forum Mach Software (ArtSoft software)
    Last Post: 11-10-2012, 05:19 AM
  5. DRO doesn't equal Movement
    By ranchak in forum Mach Mill
    Last Post: 01-26-2010, 07:55 AM
