586,082 active members*
3,837 visitors online*
    Jul 2020
    33
    4th axis retrofit
    Another day another acramatic question
    I wonder if its possible to retrofit a 4th axis to a a2100 from 2000.
    Its a machine with profibus and siemens electronics.
    Machine specs. States 4th was not as option
    But can it still be activated by user?
    Anyone done such a project and could help?
    I have a old jones &shipman unit.
    Today with sem and heidenhain encoder but ofcourse they would be swapped.
    Cheers
    Mar 2008
    285
    Re: 4th axis retrofit
    Anttoni, 4th Axis for A2100 Arrow Series-2 Model EKK with Siemens 611 drives AND Profibus.
    See EKK Attachments for Rotary Axis. There is a lot more Time & Money than you would imagine....
    William.Oehler @ fivesgroup may help you purchase options; the MAI code generation is the toughest....
    GWood
    Jul 2020
    33
    Thanks gwood for excellent answer.
    The work seems to be pretty well documented.
    Thanks for that.
    But it seems to be a bigger task then compared to
    A retrofit we made on my heidenhain machine.
    I am although curious how much that option is.
    Mar 2008
    285
    Kwirk, Control Option could be purchased from Siemens; MAI Option Code from Fives-Cincinnati-Hebron William.Oehler @ FivesGroup.com
    Cables - Custom ordered from Five-Hebron; Drive & Motor for Rotary are Obsolete unless you could source one. ETC...
    Dec 2011
    99
    A new axis must be enabled in the SIK code of the iTNC control. This is no longer available from Heidenhain. I can help with the final authorization of the axis option. [email protected]
    I was careless, only the encoder is Heidenhain, not the controller...
  1. Replies: 6
    Last Post: 03-17-2019, 02:57 PM
  2. Cadet V 5020M 4th A Axis retrofit
    By bcarlson42 in forum Okuma
    Last Post: 09-06-2018, 03:01 PM
  3. 4th Axis Retrofit VMC 760
    By jimmyjolly in forum Bridgeport / Hardinge Mills
    Last Post: 08-28-2016, 09:57 AM
  4. Need help with 4th axis drive for Bridgeport Boss 10 Mach3 retrofit
    By BDRIVEN3000 in forum Want To Buy...Need help!
    Last Post: 08-04-2014, 03:09 AM
  5. Fanuc 6m w/4th axis retrofit issue
    By cncbret in forum Fanuc
    Last Post: 04-21-2008, 06:33 AM
