586,089 active members*
3,870 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > P1H control upgrade question
    Mar 2019
    45
    Hi everyone.
    I have a ~1995 Partner 1H with a C5 control. This machine is a bit of an oddball, it has AC servos, emerson drives, a 10k spindle, and rigid tapping (that I added). The machine is in good shape and runs well, but has some file size limitations with the current control. I also have a 1997 VM16 with a C6 control that has been completely upgraded by Sportybob. I do like some of the features that the C6 has over the C5. I saw a "working and complete" C6 control box and front panel for sale on ebay and I'm curious if it's mostly plug and play to swap it out for the C5 I have now. The price seems pretty fair and my machine is in good enough condition and has the features to justify an upgrade in my opinion. Anybody have experience just swapping for a newer control?
    Chris
    Sent from my SM-N960U using Tapatalk
    Sep 2010
    529
    Re: P1H control upgrade question
    No comments? Bumping this to the top in hopes of some responses.
    Thanks!
    Jun 2013
    36
    I've got a C5 Mill, and a C6 Lathe I'm still working on.. But, they both run DOS. And DOS is most likely the limiting factor with your file size limitations. I've seen some previous posts from Sportybob talking about memory extenders or some other special DOS black magic he's used on these old machines. You can probably look at the AUTOEXEC.BAT and CONFIG.SYS that Sportybob worked on and might be able to replicate the file size upgrades on your old C5 machine. You might have to buy more memory for it, but Memory is cheap and fairly easy to find on eBay. I'd also recommend a ChipOnDisk or DiskOnModule upgrade as well. These kind of modifications are relatively easy to perform, but you'll have to know how to work in DOS.
    As far as upgrading the C5 to a C6, I think the software is completely configurable to adapt any controller to any machine. I've also got a feeling it wouldn't care about the panel either. Interestingly, my lathe boots and up and displays, "BAD V" for the control panel. The problem would be the pinouts for axis/IO as well as the drives might be different. I vaguely remember doing some searching a while back and seeing something about the single-board motion controllers use different drives from the multi-controller cards.
    What are some of the difference between the C5 and C6 controller?
    Also, How did you add rigid tapping to the C5 machine? What VFD do you have? Can you just add an encoder to the spindle?
    Jun 2013
    36
    I don't know if they had any earlier versions of the C6 controller with the same axis connectors as the C5 boxes. But at a minimum I would think you'd want those to match up for the best chance of the upgrade working.
    You can see from the pictures below just how different the X/Y/Z connectors can be.
    C5 controller:
    Here's what most of the C6 controllers I find on eBay look like.
  1. Act 3 control upgrade.... hopefully
    By peterson76 in forum Okuma
    Last Post: 08-04-2009, 07:45 AM
  2. Upgrade to PC control?
    By madkins in forum Controller & Computer Solutions
    Last Post: 12-16-2008, 09:05 PM
  3. Opinions on control upgrade
    By DareBee in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2004, 08:04 PM
