586,652 active members*
2,568 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Rotating unpowered stepper motor, good or bad
    Aug 2022
    37
    Is it bad to rotate an unpowered stepper motor?
    I want to set up my limit switches,, but I don’t have my G540 set up yet. So I was going to use a drill on the back side of my 2 shafted stepper motor to move my axis’s. Will this harm the stepper motor?
    Or I will have to take off my motors and set up couplers and a shaft.
    Thx EZ
    24223
    Re: Rotating unpowered stepper motor, good or bad
    Never had a problem with it, why do you suspect there may be?
    The harm is often when the rotor is removed from the stator.
    Albert E.
    Aug 2022
    37
    I just didn’t know if you could wreck them by spinning them. I need to move my axis to set up my limit switches while I wait for my SmoothStepper to arrive. Also the steppers are not wired up. Thought it might be fine to do so, just like double checking.
    Thx for the reply.
    EZ
    - - - Updated - - -
    Thx for the reply.
    EZ
    Aug 2005
    1100
    Quote Originally Posted by EZMEF View Post
    Thx for the reply.
    EZ
    A couple of things to keep in mind.
    1. As the steppers are not wired, if two of the wires that are part of the same coil in the stepper touch each other, it will be difficult to rotate the motor. It effectively applies a brake on the motor
    2. When you do wire them up and connect them to your controller, turning the motor by hand will generate energy and "push" it into the controller. Some controllers are sensitive to this and it can harm the stepper driver in the controller. That said many good quality drivers such as Geckodrives have protection against this.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
  1. Stepper motor only rotating one direction (RAMPS 1.4 Board)
    By L4_Topher in forum Stepper Motors / Drives
    Last Post: 10-12-2020, 04:10 PM
  2. Replies: 8
    Last Post: 08-14-2017, 10:29 AM
  3. stepper motor not rotating
    By Haitem56 in forum Stepper Motors / Drives
    Last Post: 03-08-2017, 02:32 PM
  4. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  5. Stepper rotating weight, why?
    By Spiral_72 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-14-2009, 06:19 PM
