586,076 active members*
4,061 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Controller board blowing fuse
    Post Fanuc Controller board blowing fuse
    I am trying to fix a friends CNC machine Nakamura Tome TMC-200, I have been able to replace power supply, amplifier etc as it had been sitting for a long time without use.
    I am now down to the controller board A16B-2200-066 and replaced it to find out the replacement board will need programming.
    So I have looked at the original board and found a component on it has failed, by using a thermal camera.
    It had short circuited so was blowing the 5A fuse. Photos attached of offending item is the one with 19 on it, others on the board are marked like the CZ7 one is.
    Thanks in Advance
    Regards
    Mark
    Attached Thumbnails Attached Thumbnails IMG_2645.jpg   IMG_2648.jpg   IMG_2646.jpg
    Nov 2008
    26
    Re: Fanuc Controller board blowing fuse
    Based on the location, I'd say it is a 50v Bypass Capacitor. If you pull the data sheet on the IC next to it, then check the traces to see if they route to the power and ground pins. If it does then that is most likely it. If it is a ceramic cap those fail shorted all the time. You could probably test and run without it.
    You can try and find the cap online or stick a 0.1uf cap in there and see how it goes.
    Apr 2009
    1379
    Remove it; don't bother replacing it.
    Quote Originally Posted by memoryman View Post
    Thanks for the info
    Thanks for the help
  1. Mori MV 55 fanuc 10m blowing 3.2amp fuse on I/O Board
    By James2023 in forum Mori Seiki Mills
    Last Post: 12-06-2023, 03:52 AM
  2. Blowing fuse when firing,put in new power supply and tube, still blowing fuse HELP!!
    By jeff4freedom in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-05-2020, 01:29 AM
  3. Fanuc 0M blowing F2 fuse
    By mark029 in forum Fanuc
    Last Post: 01-02-2017, 05:59 PM
  4. Replies: 2
    Last Post: 09-28-2011, 09:31 AM
  5. Mechatronics controller blowing fuse!
    By WilkBoy in forum Stepper Motors / Drives
    Last Post: 06-25-2007, 03:43 AM
