Just machined some pillow blocks to hold my Igus sleave bearings today. Used 3/4" pipe, which is about .833, reamed to .875, cut a groove inside for the strange contours on the bearings, weld a piece of channel to it, BOOM, pillow block. Took about 10min a piece...why? Because it is steel and simple. If it were aluminum, you could easily add another 20 to 30 min to each piece, after milling a flat for mounting. I am finally going to throw a machine together out of steel. Just to show the doubters if nothing else. With a space frame, multiple tube design, it should be plenty light as well as strong.
Stop talking about it and do it already!!!!!
