586,100 active members*
2,977 visitors online*
    Mikron wf31 with tnc155q
    Hello.
    I have problem with my machines y axis. So when i want to zero it, it will zero z axis normal and it will start zeroing y axis and go to zero position but on screen it wont disappear and i cant go further. So i need to restart machine and after 10-20 atempts it will zero it, but is still problem when im in manual mode i can move y axis in + but it wont move in - , and some time all axis will go only in + direction. What i have done till now exchange x and y measuring bar and servos, check cable conections. Conections looks ok and problem stayed on y axis. There is no error code and when i press - direction it will show feed rate but machine wont move. So my ideas stops here can somebody help me what else to check.
    Thanks, Simon
    Mar 2016
    325
    Re: Mikron wf31 with tnc155q
    Maybe just limit switch stucks and when u hit it it stays on, so machine thinks it can not go any further in this direction.
    I had the same problem about half year ago. Y axis limit switch is located in a place where old grease from cariages drops on it and after 30 years it can get glued a little.
    Hello.
    It is not limit switch i check all of them. Sometime y axis dont go reverse and sometime all 3 axes dont go reverse.
    Does anybody have an idea what could be wrong?
    Thanks, Simon
  1. Bridgeport Interact 520V/Heidenhain TNC155Q problem
    By RS232 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2016, 07:47 PM
  2. NEED HELP/ Touch probe to suit Heidenhain TNC155Q controller
    By jacel in forum Want To Buy...Need help!
    Last Post: 01-15-2015, 05:11 AM
  3. Need help Mikron WF 21 D
    By Griff34 in forum Milling
    Last Post: 11-27-2014, 03:00 PM
  4. Replies: 1
    Last Post: 08-03-2014, 07:55 AM
  5. Mikron WF 21 D
    By fly2084 in forum HEIDENHAIN -> GENERIC
    Last Post: 09-11-2008, 03:58 PM
