586,113 active members*
3,122 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > SRAM backup for mori seiki NV4000 DCG
Results 1 to 6 of 6
    Jan 2016
    17
    My machine rested for more than 1 year and when I started it it had lost all SRAM data because the backup battery ran out.
    does anyone in this group have a backup of SRAM mori seiki nv4000 DCG parameters? will you share with me, or i can pay for it. Thank you in advance.
    My message to Fanuc users: You have to back up at least once every 6 months, don't be like me, only realizing after everything is gone
    My email : [email protected]
    Aug 2009
    1573
    Re: SRAM backup for mori seiki NV4000 DCG
    ...does this Fanuc Controller have a HDD?
    What is the Controller Model number?
    Jan 2016
    17
    Quote Originally Posted by machinehop5 View Post
    i have found it on front end display pc. in DNC folder..btw thanks.
    Jan 2016
    17
    the number is A02B-0283-B803
    no HDD but CF card, i was found it by searching every folder on host front end pc.
    btw thanks
    Aug 2009
    1573
    ...there might be a Backup file on the CF drive.
    DJ
    Jan 2016
    17
    All sram reset process has done from IPL mode by switching rotary key. but we are facing another problem the control wont finish boot, 7 segment start light up from 8, F, and then stuck at 9.
    Does anyone know which part is the problem?
  1. Mori seiki NV4000 DCG
    By blizzzard30 in forum G-Code Programing
    Last Post: 12-26-2023, 06:57 PM
  2. Replies: 4
    Last Post: 12-26-2023, 06:54 PM
  3. Okuma MB4000H vs Mori Seiki NH4000 dcg
    By MicMeadow in forum CNC Machining Centres
    Last Post: 07-07-2020, 05:55 AM
  4. Mori Seiki NH DCG HMC's ? Any good?
    By glovebox20 in forum Mori Seiki Mills
    Last Post: 09-21-2013, 03:04 AM
