586,379 active members*
3,548 visitors online*
    Dec 2004
    37
    Omax Charge Pump Pressure Low Issue
    Hi all. I've been having an intermittent problem witht my Omax 2652. On some occasions the machine works fine and then on other occasions I get the charge pump pressure low fault not allowing the pump to start. I replaced the pressure switch and it started working, but then stopped working the following day when I turned on the machine. Got a second presssure switch thinking there may have been an issue with the first replacement pressure switch, but the second one did not work. Subsequently put the first switch back in and it started working again. However, it has since stopped working again. Yesterday I tried to run the machine and same error. I let it sif for probably a half your and the pump turned on for about 3 seconds and then shut down and got the charge pump pressure low fault again.
    I have replaced the charge pump and there is 130psi on both sides of the prefilter and final filter. There is plenty of water in the white water tank as well.
    Curious if anyone could maybe shed some light on this for me.
    Thanks so much
    Jan 2020
    47
    Quote Originally Posted by powerfade View Post
    Thanks so much
    Hi
    Check the pressure readings when you fire the pump through the dump valve, (pump only) do you still hold a steady pressure of 130PSI, or does this drop below 80PSI
    Dec 2004
    37
    Re: Omax Charge Pump Pressure Low Issue
    Hi Neil. I really appreciate you getting back to me so quick. I tried to run the test through the test pump only (dump valve open) command and nothing happens. The timer starts and the pressure stay at 130psi on the gauges, but the pump does not turn on at all. I sent you a PM as well, but figured I would put it here as well in case it would help someone else out in the future.
    Thanks again Neil
  1. Omax P2040 pump rebuild help
    By gpw123 in forum Waterjet General Topics
    Last Post: 10-31-2018, 07:58 PM
  2. OMAX 2652 Issue. Help?
    By DanielMartin2652 in forum Waterjet General Topics
    Last Post: 07-06-2018, 11:38 AM
  3. Omax 5555 - cannot lower pressure to 20 KSI
    By AvalignMaint in forum Waterjet General Topics
    Last Post: 10-03-2017, 04:00 PM
  4. Alarm 121, Low Lube or Low Pressure
    By tjamscad in forum Haas Mills
    Last Post: 11-12-2013, 10:54 PM
  5. High pressure low volume water pump
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 08:36 AM
