586,103 active members*
3,224 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > castrol Hysol MB 50 cutting fluid
    Anyone here using Hysol MB 50 . Due to supply issues and pricing I'm looking at alternatives to the hocut 795b I've been using .
    I dealt with a number of staining issues on my aluminum parts in the past until I came across the hocut which is fantastic coolant . Every time I order from my supplier the price keeps going up and my supplier said they keep getting the same complaint as mine , enough so that they are planning to drop carrying that fluid .
    Favourites I've used in the past have been discontinued or had formula changes that eventually didn't work fly with my parts . Castrol is one brand I don't recall ever using though they've been around a long time , and the price on the mb50 is pretty inviting as are the specs
    Anyhow if anyone is using it then a bit of feedback would be appreciated . Otherwise I'll probably order some anyway to try it out , and if it doesn't work then I'll add it to my never ending supply for my saw . The main concern is staining on aluminum
    Dec 2008
    3109
    Re: castrol Hysol MB 50 cutting fluid
    We have the mb50 in our shop, have tried to order stock, and have been advised that the mb50 is being discontinued in Oz,
    I've been advised that there is a Co that seems to have "cloned" that coolant, but with OH&S, safety sheets (SDS), pricing etc requirements. That option was canned.
    I have used the Hocut 795 before at an aerospace Co, (lots of various metals being cut) didn't stain alum. Properties are similar to the mb50.
    I ordered 20 lts. for the guys to trial after exhausting the mb50 stocks.
    thanks good to hear . I really like the hocut but the supply and price here is less than impressive
    It looks like a supplier here in Canada has the mb50 which shows a lead time of 1-1.5 weeks , so I'm hoping that it isn't being completely discontinued . If it is then I'll have to find out what their next best formula is .
    If I ran mills with big tanks then I'd be buying in drums but a 5 gal lasts me a bit with a lot of topping up with water to keep the concentrate levels in check . The castrol is $150 cheaper for a 5 gal than the hocut and if it behaves the same then I'll be happy
  1. Homemade cutting fluid?
    By pp7 in forum Benchtop Machines
    Last Post: 09-22-2018, 12:28 PM
  2. What cutting fluid do you use?
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-10-2012, 08:37 PM
  3. Cutting fluid for aluminum?
    By Ben in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2011, 04:03 PM
  4. What cutting fluid are you guys using?
    By douglasco in forum CNC Swiss Screw Machines
    Last Post: 07-13-2009, 01:02 PM
  5. Cutting fluid
    By sleeper142 in forum Haas Mills
    Last Post: 07-29-2007, 02:05 PM
