Due to drive failure I had to connect a different drive. When it comes home on the Z Axis, it goes down and hits the counter and gives an error. Can I fix the reverse movement of the drive?
https://youtube.com/shorts/BTcctH5K2FI?feature=shared
You have to program the drive to the correct axis, you might be able to call Multicam for the drive parameters.
You will need the teknics communication software and cable to talk to the drives or if your machine has the 2125 and newer control board you may be able to use the controller to reprogram the drives.
