586,115 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Do I have a bad Amplifier
    I've been asked to work on a Fadal VMC 5020A year of MFG 1997. I know very little about the machine and have not been able to find the manual for it. It is experiencing and amplifier fault.
    Upon investigating, I noticed that there were 3 devices in the electrical cabinet that appear to be servo amplifiers with a part number of SMA-8520-3. Two of them had green lights illuminated and one had no lights illuminated. I quickly realized that there was a 20A incoming fuse in line with the B+ terminal of the amplifier and that it was blown. I replaced the fuse with a new one which resulted in another blown fuse. With this fuse now removed, I measured the resistance between terminals B+ and B- and found it to be less than 2 ohms. Upon removing the fuses from the other 2 amplifiers, I performed the same resistance measurement between B+ and B- on the other two amplifiers and found each to give a reading in around 5k ohms if I remember correctly. All measurements taken with the power off.
    In addition, I've noticed 2 other devices which have "Advanced Motion Controls" written on them. These two devices are also labeled as servo amplifiers. Upon powering on the machine, I see that one has an illuminated red light while the other does not. The fusing here seems okay but its unclear to me what these actually do since there are only 2 of them.
    I suspect that the SMA-8520-3 that keeps blowing a fuse is to blame here for the servo amplifier fault but am unsure since there are two sets of hardware that seem to be called "Servo amplifiers". Ill attach photos of each set of amplifiers mentioned.
    Any insight on the issue would be appreciated.
    Attached Thumbnails Attached Thumbnails IMG_7666.jpg   IMG_7665.jpg   IMG_7664.jpg
    Sep 2009
    103
    Re: Do I have a bad Amplifier
    The three gold amplifiers (AMP-0029) are AC power for the x,y and Z axis. Notice the labeling on the encoder cables for which is which.They are interchangable so try swapping two of them to see if the problem follows. If the problem doesn't follow, Then its prolly the motor for that axis.
    The two AMP-0014 are DC amps to run either an A or B axis or some other servo. They are also interchangable. There are tuning procedures for each type of amp.
    Aug 2009
    1573
    ...here is a place to get Fadal Manuals
    https://flintmachine.com/fadal
    Good luck,
    DJ
  1. Bad connectionof the cable or bad bob
    By Lc1975 in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2015, 06:49 PM
  2. Bad ball screw nut or bad bearings?
    By GITRDUN in forum Haas Mills
    Last Post: 01-19-2015, 05:03 PM
  3. Precix 9100 -Copley Controls 800-700 Servo Motor amplifier went bad
    By wdysf150 in forum Servo Motors / Drives
    Last Post: 12-18-2013, 01:59 PM
  4. FANUC 11M Amplifier bad, need help!
    By posedi in forum Fanuc
    Last Post: 11-11-2009, 04:50 AM
  5. FANUC 11M Amplifier bad, need help!
    By posedi in forum DNC Problems and Solutions
    Last Post: 04-19-2006, 04:10 PM
