hi
could you help me ,please
I have a cincinnati hawk lathe how Convert the controller to inch???
active setup # 1 is G71 metric unit
thanks
hi
thanks
A2100 Programming Modes: (Inch / Metric) ETC...
Select > MORE>> > Service > Type the "service" password; hit enter and "Commit Changes". Level will display as SERVICE
Select > MORE>> > System Configuration > NC Programming > Select the TAB, MODES > Select and change the values
that you want the control to RESET To at Power-On, Data Reset, End of Program, etc.
When you are finished "Commit Changes" and then follow the procedure to Backup your changes. (See Attached Procedure).
"_A2100_Archive_Backup-Restore_Procedures.pdf" (93.7 KB)
This is extremely important if you have to replace a hard drive, or something gets corrupted due to a hardware / power failure.
When you are finished go back to the service screen, Type any "key"; hit enter, You'll get passwords don't match and "Commit Changes".
Level will display as OPERATOR, where Config screens can be looked at (displayed) but not changed or screwed with!
