586,395 active members*
2,919 visitors online*
Results 1 to 9 of 9
    Something is crazy with my CNC
    Hi everyone, got some more issues, I´m trying to design a simple box with ply and want to get the test fit right, so go into fusion 360, do my stuff, bring it to mach 3, (mach 3 previews everything fine) and when i enter the run command, it does the top part fine, but the bottom part is just wrong, I can´t understand how this would happen. I think everything I have are quality parts except for the cnc controller which is novosum and doesnt seem too clever. Any thoughts?
    I completely re designed everything in fusion and the same thing happened
    In the photos you can see what is supossed to be happening and what my machine does, thanks for any help.
    Re: Something is crazy with my CNC
    Here is the gcode, even though i cant read it personally.
    Attached Files Attached Files
    Nov 2014
    724
    Can you export your F360 file and upload it here? The f3d file may have to be zipped to upload it.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Im on it
    Nov 2014
    724
    The simulation looks correct. Which post processor are you using? Also, is one part suppose to fit into another? It looks like they will but I'm just curious about the different designs of each piece and wondering what fits with these.
    David
    Romans 3:23
    one part should fit into another at 90º so at a corner, post processor is mach 3¿? dunno whats wrong, why only half the design? top half is fine, bottom half crazy, i redesigned it in fusion using bottom half specs and mirroring and it still does some weird mumbo jumbo
    Mar 2016
    325
    Did the machine worked earlier with no problems?
    Looks like huge backlash, or loosing steps on turnovers, which could be caused by to high acceleration.
    Ok I finally got it to work fine by basically slowing it down a lot, I was going like 15.000mm a min or 600 inch for optimal chipload, but just way too fast for the machine, even though I thought it was impossible for the motors to skip without a warning because they are closed loop, or do I have to wire something back into the drives?
    Mar 2016
    325
    U should have encoders connected from motors to drivers. Anyway closed loop steppers don't work the same as servodrives. The drive just makes alarm signals when motor loses more than set amount of steps ( usually half or one rotation)
  1. My CNC has gone CRAZY please help
    By Plapath in forum Chinese Machines
    Last Post: 10-31-2019, 09:41 PM
  2. crazy cnc router
    By sr romo in forum Spanish
    Last Post: 09-26-2013, 08:10 PM
  3. Ongoing Saga of a CNC Gone Crazy
    By IQChallenged in forum Gecko Drives
    Last Post: 07-16-2008, 01:22 AM
  4. Crazy CNC Idea
    By watzmann in forum Community Club House
    Last Post: 10-09-2005, 05:58 PM
