586,201 active members*
4,063 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Circuit Breakers and Contactors Vendors and Brands
    Jan 2024
    Need to order main circuit breaker, contactor and branch circuits breakers and few other odds and ends.
    I can piece together what I need from automation direct however my OCD would like to keep most of the stuff in the same brand.
    Any recommendations on vendor sites I should be shopping and specific quality brands? Eaton Schneider Siemens...
    This is for a three axis one phase 240v CNC Mill using DMM DYN4 drives and Servos using LinuxCNC or UCCNC.
    24221
    Re: Circuit Breakers and Contactors Vendors and Brands
    The enclosures I build uses DIN rail mount devices, It used to be Telemecanique brand contactors etc, , which is now produced by Group Schneider.
    Albert E.
    Nov 2013
    4380
    here is New Zealand many brands are represented but Schneider is one of the most common. You can get breakers, contactors, overload blocks, isolators and
    switch blocks all within one brand, Schnieder. I'm not aware that any particular brand is better than any other, at least for our purposes.
    For circuit breakers I like these, they are not DIN rail which is a drag, but otherwise they are good.
    https://nz.element14.com/potter-brum...c/dp/156649001
    Don't much care about the brand, they are all much of a muchness.
    Craig
    24221
    I also used what was then the Telemecanique brand of P.B. Switches etc.ZB2/XB2 series, I see that China is now making a knock-off of them.
    Albert E.
  1. Selecting Circuit Breakers for CNC Control Box, VFD, and DC Power Supply
    By 1875 in forum CNC Machine Related Electronics
    Last Post: 02-02-2016, 04:41 AM
  2. Contactors in control panel
    By soymilk in forum Tormach Personal CNC Mill
    Last Post: 05-16-2015, 04:55 AM
  3. snubber circuit for AC contactors and solenoid coils.
    By howanc7 in forum CNC Machine Related Electronics
    Last Post: 02-18-2014, 04:13 AM
  4. circuit breakers
    By JamesKain in forum Maintenance DIY Discussion
    Last Post: 12-26-2012, 03:49 PM
  5. Contactors
    By RP Designs in forum CNC Machine Related Electronics
    Last Post: 06-26-2009, 05:11 PM
