586,103 active members*
3,260 visitors online*
    Dec 2007
    7
    slow performance issues
    I am not happy with the planet cnc performance on my plasma table. This is a new installation replacing mach 3. What I am seeing is that I am not achieving close to the desired feed rate as the controller appears to be processing each line of code as a separate move.
    For example this is a portion of my code, and or each line of code the controller will initiate a move with acceleration, and deceleration to almost zero before beginning the same thing with the next line of code?
    Any suggestions?
    G01 X3.0889 Y13.7013 F85.0
    G02 X3.6559 Y13.7923 I1.5744 J-7.9991
    G02 X4.2173 Y13.7998 I0.3144 J-2.4930
    G01 X4.2180 Y13.7997
    G02 X4.7636 Y13.6673 I-0.3164 J-2.4927
    G02 X5.2234 Y13.4842 I-2.7848 J-7.6622
    G01 X4.8233 Y14.1435
    G01 X4.2817 Y14.5040
    G02 X4.2956 Y14.5498 I0.0139 J0.0208
    G02 X4.8694 Y14.5285 I-0.0164 J-8.1525
    G02 X5.4215 Y14.4264 I-0.1780 J-2.5064
    G01 X5.4221 Y14.4261
    G02 X5.9314 Y14.1898 I-0.7966 J-2.3831
    G02 X6.3466 Y13.9205 I-4.2261 J-6.9717
    G01 X6.0829 Y14.6452
    G01 X5.6220 Y15.1045
    Craig
    Jun 2017
    119
    Re: slow performance issues
    Are you using sheetcam for nesting?
    Dec 2007
    7
    Quote Originally Posted by MrEmo View Post
    not for nesting on this one, imported a dxf into sheet cam and posted it from there though.
    Jun 2017
    119
    Probably some settings inside planet cnc software then. I am moving away from planetcnc now due to so many issues over the years. Hopefully you are a bit more lucky.
    Mar 2017
    1312
    This happens because motion planner optimizes your machine motion depending on the path blending tolerance and your max speeds, and max accelerations/decelerations.
    So in order that your machine reaches speed set in program with F value, you would need to set these values higher:
    https://cnc.zone/kb/tutorials/essent...d_acceleration
  1. HSM/Fusion 360 slow motion issues
    By yoshimitsuspeed in forum Shopsabre
    Last Post: 04-02-2023, 03:56 PM
  2. Sprutcam 10 Updates and Performance Issues
    By grimms3 in forum SprutCAM
    Last Post: 11-29-2016, 08:42 PM
  3. Bystronic Bystar 2512 performance issues
    By pmcenaney in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2014, 10:34 PM
  4. Performance Issues
    By hessex in forum Commercial CNC Wood Routers
    Last Post: 10-15-2012, 10:37 PM
  5. Replies: 48
    Last Post: 07-19-2008, 04:54 AM
