586,461 active members*
4,464 visitors online*
Results 1 to 8 of 8
    Nov 2023
    8
    Solidworks CAM post processor
    Hi all,
    I use Solidworks CAM (not SolidCAM). Where should I put the PlanetCNC post processor files (.gpp and .vmid) so they will be taken into account by Solidworks? In particular, there is no 'GPPTOOL' folder in Solidworks installation.
    Mar 2016
    325
    Re: Solidworks CAM post processor
    Gpp and vmid won't work with solidworksCAM.
    - - - Updated - - -
    Nov 2023
    8
    Yes, I finally found that too :-(, thanks for your reply.
    So I use the Mach3 post-processor in SolidWorks CAM, and it seems to work, at least with the simulation in PlanetCNC. Will see later if it works with the real machine...
    Nov 2014
    21
    Did you ever get this to work ?
    Nov 2023
    8
    I just finished to mount & wire everything, including limit switches. As previously said, it seems to work with the Mach3 post processor in SolidWorks CAM, but I'll see with the first metal cutting soon. I'll keep you informed of the results. For the moment, I'm very positively impressed by the quality of the TNG software which works like a charm :-)
    Nov 2014
    21
    Awesome Buddy Thanks
    Nov 2023
    8
    I confirm that with one of the Mach3 post-processor (there are two, with and without G54 gCode) PlanetCNC works flowlessly with my "Harbor Freight" like mini-mill.
    Nov 2014
    21
    Awesome Thanks Gixy
  1. CamWorks/SolidWorks CAM Post Processor help
    By esmith2058 in forum CamWorks
    Last Post: 04-11-2023, 09:28 PM
  2. Replies: 1
    Last Post: 09-30-2020, 06:19 AM
  3. Solidworks CAM Post Processor for Mach 3 machines.
    By JTulley in forum Tormach Personal CNC Mill
    Last Post: 04-02-2020, 09:07 AM
  4. Anyone have a YASNAC MX3 post processor for Solidworks CAM?
    By gmoushon in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-15-2019, 05:15 PM
