586,096 active members*
3,012 visitors online*
Results 1 to 12 of 12
    Jan 2024
    8
    Exclamation Fanuc Oi Mate-TB : 1006
    CNC had a hydraulic leak, from a seal between the Turret and Spindle. Gearbox was stripped, cam was removed to replace the seal, on assembly the sensor timing went off. I did have 1007 - Turret Counter Error, which I resolved.
    Symptoms : Turret not locking
    Error : 1006
    What are the significance of the red lights at the rear of the turret ?
    - Position 1 (3 red lights) , Position 4 (1 red ) , Position 5 (2 red ) , Position 7 (2 red) , Position 9 (2 red) , Position 10 (1 red)
    Please help me with this.
    Unable to upload the video, click the Google Drive link for the file.
    https://drive.google.com/file/d/12a9cNjYByVqAbsGOTSLBbZYvLEVlRfqN/view?usp=drive_link
    Apr 2018
    134
    Re: Fanuc Oi Mate-TB : 1006
    Note the Google Drive video link doesn't work for me due to a 'permissions' issue. IMO its likely others will also see a similar message. YouTube may be a better choice.
    - - - Updated - - -
    Jan 2024
    8
    Thank you for informing me, here is the Youtube link : https://www.youtube.com/watch?v=dTerGYz8Bv0
    Below are the plate specifications :
    Dec 2009
    953
    First thing you have to do is that when you call T01 you should be sure that the tool is in the center of the spindle and not above or under the spindle line so you know mehcanical the turret is coming correctly
    after this is done ,you need to adjust the sensor cam for specific tool decode
    As far as i see you can adjust the cams that make the sensor confirm
    Ussualy in the electric book you should have the combination of the sensors for tool numbers ,something like this-this is an example
    000-T01
    001-T02
    010-T03
    011-T04
    100-T05
    101-T06
    110-T07
    111-T08
    You need to check in the book what order is for your turret
    Should be also a sensor for turret clamp but i do not see it in your video or photos.
    do you have the electrical book?
    Jan 2024
    8
    Thank you for responding, I don't have the electronic book unfortunately , would you kindly guide me on how to download one and which specific one I should find ?
    Jan 2024
    8
    Unhappy Re: Fanuc Oi Mate-TB : 1006
    The Manual's shown is what I have managed to attain for my machine, would really appreciate the guidance to get this machine in working order. I am based in South Africa - Kwa Zulu Nata - Durban , I have made attempts with several specialists who just became a financial affair as they never resolved the matter.
    Dec 2015
    171
    Jan 2024
    8
    @phucrobusl , Please confirm that the email is correct as I have sent an email to that address and received a response that I have the wrong person.
    Jan 2024
    8
    Dec 2015
    171
    Jan 2024
    8
    Quote Originally Posted by phucrobusl View Post
    Hey buddy, I have sent you an email. Would really appreciate your help.
    Jan 2024
    8
    Please could anyone assist me, would appreciate any help if based in South Africa
  1. Fanuc O-M Alarms #1006 and #409 on crt
    By imcmach in forum Fanuc
    Last Post: 11-22-2017, 08:22 PM
  2. Replies: 5
    Last Post: 11-13-2017, 04:45 PM
  3. fanuc drillmate / robo drill alarm 1006 clamp
    By goodplastics in forum Fanuc
    Last Post: 07-30-2015, 12:19 PM
  4. fanuc o-t alarm 1006 tool position error
    By Korellibopper in forum Fanuc
    Last Post: 11-18-2011, 06:48 PM
  5. Fanuc O-m Alarm 1006
    By CNCEDMDUDE in forum Fanuc
    Last Post: 09-01-2006, 02:13 AM
