586,116 active members*
3,502 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CNC Cutting Aluminum - Newbe Question
Results 1 to 1 of 1
    Jan 2024
    Newbe question here -
    I have the opportunity to start a small side-gig in a very niche market with 2024 T3 aluminum, no more than 1/8" thick. Will need to be able to make precision cut-outs, some very small (3/16"). What is the best method for this? Laser, CNC router, CNC Plasma, etc? Any help would be appreciated.
    Nov 2013
    4376
    Re: CNC Cutting Aluminum - Newbie Question
    for highest speed and therefore lowest overall production cost I'd say laser. The finish of laser cut aluminum is not perfect, you'd want to try one or two parts as a sample to determine if the finish is acceptable.
    If not the cost of refinishing may tip you towards vertical CNC milling.
    A laser machine to cut 1/8th aluminum with speed and quality is not really an affordable machine to own, you'd be better off contracting that work out to a company that has made the investment already.
    Milling aluminum requires a very rigid machine. Some of the bigger and more expensive CNC routers are rigid enough to do a good job in aluminum, whereas the smaller cheaper machines are not.
    A more conventional mill like a Tormach will do a good job, and is affordable, or even better a Hass mini-mill, if you want to 'own' your own machine. Otherwise there are dozens of companies
    out there whom have machines ready and waiting to go.
    A well sorted mill, and probably does not need to be a huge and expensive machine, will run small tools, say 1/8th or 3/16th with good results. It will be slower...but then should require no re-finishing.
    Things like a chamfering pass sure do make a part look professional.
    Craig
    Nov 2020
    13
    It all depends on what you mean by precision. You can't make in in this business without exact dimensions and tolerances. To many 1/100th of an inch is more precise than they have ever seen, a general machinist might say it's 0.001" but someone in tool and die might say precision starts at 0.0001". Some machinists seldom work smaller than 1/4" inch and to others that is huge. Check out clickspring, he often makes entire parts smaller than 3/16". For him a small slot is under 1/64".
    Plasma is out. Water jet is possible as long as the work is fairly large and will not fall into the tank.
    It's a tossup between laser and router, a VMC might be slightly more accurate if you can tolerate rounded corners. Wire edm is likely the most precise.
    The number of parts per run is also a big factor here.
    There is a 1000x cost difference between these options depending on your tolerances and run size.
