586,096 active members*
3,779 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Slow toolpath down at end of straight line cut
Results 1 to 1 of 1
    Jan 2022
    We have a DMS CNC router that cuts a rectangle along the outer edges of a door. Along one of the long edges, we would like to slow the tool path down for the last few inches in the X direction.
    We have the first part of the path at one speed, then the remaining toolpath on the next line at another speed.
    Example:
    G90 X75 F200
    G90 X80 F50
    But when we do that, the spindle stops moving for a second or 2 when going from one line to another, and leaves a rounded gouge in the door where it briefly stopped.
    Is there a way to program this to make it slow the toolpath at the end without it stopping for a second.
    Our controller is a Fagor 8037.
    Aug 2009
    1573
    Re: Slow toolpath down at end of straight line cut
    ...G05 or G07 may or may not change anything but, does effect the look ahead the control uses for accel/decel block to block.... try changing from what ever default is on your control. See what happens with a dry run.
    https://www.helmancnc.com/fagor-8037-g-codes-m-codes/
    DJ
    Apr 2018
    134
    Here is an ealier thread that discusses G05: https://www.cnczone.com/forums/gener...g05p10000.html
    - - - Updated - - -
    Here is an ealier thread that discusses G05: https://www.cnczone.com/forums/general-off-topic-discussions/31214-wat-mean-g05p0-g05p10000.html
