Ive wired my one up to the letter as per manual. Went through all the jog startup stuff no problem.
Gear ratio is set. Currently have it SIG/PUL through a couple of 2222 transistors and they are checked out as working. Im just having trouble working out the DI stuff, especially the pulse command inhibit input function that I think is the issue possibly as the motor shaft is free to spin. A free spinning shaft means to me its not looking for a pulse at all almost like its in the wrong mode but I cant find any other settings.
So a quick question asking is someone familiar has time to give a real fast rundown on how the DIs are set, and if anyone knows about how this pulse inhibit command is sorted? I dont understand the logic at all nor the tables in chapter 7. Gee it would be nice if it was like a VFD with the setup, I cant even understand the literature and I am definitely not a novice engineer. Well. I am a novice at setting up a industrial servo drive anyway.
I have a programming cable on its way but it would be nice to at the very least get this motor to control through my system which is Mach 4 ESS.
Many thanks in advance. At least the motor ran nicely on jog-test-mode. Definitely a step up. Just it is not even looking at my inputs for now.
