Hi Everyone,
I have a Mk3/4 and Extinout expansion board with NPN proximity sensors connected to extin ports. Everythings works perfectly, now I need to use the extin1/2/3 as limit switches, but it's not possibile to select it in the settings menu.
Is there a workaround for this, or I need to request a new feature of TNG V2?
Same problem with the extout: I have coolant and mist pumps connected to the relays, they work only when I select the extout channel, but I can't assign them to mist and coolant in settings. Any way to do this?
Thanks!
