586,570 active members*
3,430 visitors online*
    Jan 2024
    Machine for foam - smaller than 8x4
    We currently have an 8x4 Biesse Rover, which we mostly use for birch ply. We are doing a lot more with offset pocketing/cutting foam inserts, using Plastazote LD45 and similar.
    None of these inserts are larger than about 800x400mm, so it takes up a lot of room on our Rover that then can't be used for processing ply. We'd like to get a smaller (4x4?) machine to deal just with foam. We don't have room for a second 8x4.
    So, I'm looking for a machine (available in the UK) that can do:
    - Strong, ideally zoned, hold-down power from a vac bed
    - High spindle speeds (20k rpm), used with a down-cut foam cutter
    - 4x4 or smaller
    - Possibility for an oscillating knife attachment would be excellent but not essential
    Any ideas what would be available please?
    Re: Machine for foam - smaller than 8x4
    100mm EVA Foam with POT knife head
    https://youtu.be/4f8cxExm14k
    Jul 2018
    6410
    Hi - Whats a POT knife head? Does it cut tangentially or is the blade round? Peter
  1. Help a Newb Build an 8x4 Machine ????
    By LondonBoards in forum Mechanical Calculations/Engineering Design
    Last Post: 10-18-2021, 11:00 PM
  2. Replies: 0
    Last Post: 04-02-2018, 02:48 PM
  3. Machine cuts are slightly smaller than on drawing - help
    By FoxCNC1 in forum Uncategorised WoodWorking Machines
    Last Post: 12-26-2013, 05:47 PM
  4. 8' Parts on a Smaller Machine
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 01-07-2013, 05:07 PM
  5. Recomendations for smaller machine?
    By rlrhett in forum DIY CNC Router Table Machines
    Last Post: 01-19-2007, 05:00 AM
