586,110 active members*
3,294 visitors online*
    Jan 2011
    129
    Mach3 quit working.
    Configuration: windowsXP, PMDX-122 parallel port motion controller. Taig disc top mill.
    Been running this configuration for years and all of a sudden it quit working.
    Tried lots of things to get it running again, but can’t.
    Here is something I think is unusual that may lead to the solution .
    When I run the diagnostics with Mach3 and I click on the “mist toggle “, the red light on output #4 flashes on and off. See attached photo.
    This should not happen since I do not have output # 4 enabled in the “output list”, see attached photo.
    Any suggestions would be greatly appreciated,
    Chuck 767
    Jan 2011
    129
    Quote Originally Posted by chuck767 View Post
    Chuck 767
    Well, it turns out output 4 is flashing when I click on “mist toggle” because I have enable “Mist” in the spindle set up and it is associated to output 4.
    So this doesn’t help solve the problem I’m addressing.
    So it looks like this discussion is closed.
    Nov 2013
    4376
    Re: Mach3 quit working.
    I use Mach4 and an Ethernet SmoothStepper and have done for 8.5 years. Prior to that I used Mach3 and a parallel port. Mach4 and an ESS is light years ahead.
    It has been such a long time that I used Mach3 that I doubt I will be of much help.
    Have you run the pulse engine test utility. It sounds like the parallel port motion driver is not working.
    Craig
    The xml may have become corrupted , it happens sometimes . Have you tried pulling one from the backup folder ?
  1. Run from here quit working
    By chasxjs in forum Mach Plasma / Laser
    Last Post: 10-03-2014, 02:45 PM
  2. Motors quit working
    By 3Dsigns in forum Automation Technology Products
    Last Post: 10-17-2013, 07:50 PM
  3. Z AXIS JUST QUIT WORKING
    By BALLISTIKIDD in forum Controller & Computer Solutions
    Last Post: 10-02-2011, 05:24 AM
  4. Machine quit working
    By rnponti in forum Gecko Drives
    Last Post: 07-10-2011, 12:54 PM
  5. ncEdit quit working
    By Cameo in forum Surfcam
    Last Post: 06-28-2007, 06:47 PM
