586,100 active members*
2,581 visitors online*
    Apr 2017
    8
    Mill engraving
    Hoping you can point me in the right direction here.
    I'm trying to machine engrave on the OD of a cylinder using the A axis rotary on my Fadal to rotate the cylinder in order to wrap the engraving.
    The machine is a 1995 904-1 VMC 2216.
    Do you know if there is a canned cycle or Macro that will facilitate this type of engraving on the Fadal?
    Thanks!
    Aug 2009
    1573
    Re: Mill engraving
    ...It's a little tricky to do and it has been awhile sense I did this A axis Engraving on a Fadal 4020HT machine.....Cam Wrapping is one part of programming needed with a Fixed Subroutines L9201 for the Engraving part.
    read thru the Flat Cam part of manual here will help to understand the
    A axis Ratio part.---> https://nxgenparts.com/content/User%...otary_Axes.pdf
    Fixed Sub's --->https://nxgenparts.com/content/User%...ubroutines.pdf
    Then, look at my Program samples of a Sine Wave(IN MANUAL SOME WHERE) and a program for A axis Engraving I wrote for my name. This should help to understand what your Program should be like. Double check these programs using Graphic's or Dry Running 1st.
    DJ
    Dec 2022
    Re: Mill engraving
    Jinan Rhino CNC Equipment co.,ltd produce devise 5 axis cnc router, 4 axis cnc router and laser machines here more than 18 years. If you need a new high quality cnc machine welcome to contact us : www.rhinocncmachine.com
    Apr 2017
    8
    Re: Mill engraving
    Thank you DJ, I'll check them out.
