586,113 active members*
3,195 visitors online*
Results 1 to 7 of 7
    May 2009
    1332
    Transferring Mach3 to Another PC
    I have Mach3 running my CNC on a Windows 8.1 laptop and I want to replace the laptop with a desktop pc running Windows10. Can I just copy my .XML file from the laptop to desktop and all will be fine or I should configure the desktop from scratch?
    Nicolas
    Aug 2005
    1094
    Re: Transferring Mach3 to Another PC
    Yes you should be able to copy the .xml across.
    That said, I’d recommend going through all the configuration tabs including the motor tuning values and write them down just in case something goes wrong.
    It’s good practice to do this regardless of whether you’re transferring to a new computer or not. Just in case the computer dies.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    May 2009
    1332
    Thanks Peter, actually I always snip (take a picture) of all configuration tabs / motor tuning of my setup. I find it faster and much easier to read all details
    Cheers
    Nicolas
    I always copied the whole mach folder from the old computer , installed mach on the new computer then copy pasted and overwrote the newly installed mach folder in C: .
    May 2009
    1332
    Quote Originally Posted by metalmayhem View Post
    Well the idea sound good but in my case I have Windows 8.1 in one pc and Windows 10 in the other. No idea if it will work.
    Nicolas
    It worked fine for me migrating from xp to 7 . it's all the same folder and installed components no matter the windows system , there is no reason for it not to work . You'd just need to install mach and the necessary drivers that you currently have installed , then overwrite the folder so that you pass along your configurations and any screen mod's or anything of the sort .
    I backed up all my older machines this way and this is what I did every time I blew up a computer
    May 2009
    1332
    It worked fine for me migrating from xp to 7 . it's all the same folder and installed components no matter the windows system , there is no reason for it not to work . You'd just need to install mach and the necessary drivers that you currently have installed , then overwrite the folder so that you pass along your configurations and any screen mod's or anything of the sort . I backed up all my older machines this way and this is what I did every time I blew up a computer
    I understand, thanks. As you say I don't see a reason why it will not work so I will give it a try when I'm ready to do the switch.
    Nicolas
  1. Need help transferring programs
    By morette in forum News Announcements
    Last Post: 02-06-2023, 10:11 AM
  2. transferring license
    By SteveL86 in forum MadCAM
    Last Post: 10-10-2015, 05:29 AM
  3. Transferring a Counter Value
    By Adam Rehorn in forum Fanuc
    Last Post: 05-19-2009, 01:41 PM
  4. need help transferring cam
    By chadillac in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2009, 07:45 PM
