I'm new to CNCZone, and fairly new to the hobby. I should be finishing up my first desktop machine next week but I wanted to run a few details of my machine past you all and see what you think. Keep in mind as you answer that I'm only looking for accuracy of about .03.
Machine Basics:
-Aluminum 2"x4" tube frame.
-Moving surfaces 1" thick HDPE
-Part moves in Y Direction
-Spindle (dremel) moves in X and Z
-Machineable area 8"x7"x3.5"
-drive system is a belt drive, running 1:1 ratio to a 1/4"-20 rod in all directions.
Question 1 - The 1/4-20 rod spins in two mounted 1/4" needle bearings. (ie. I'm not turning down the shaft to remove the threads) Will this be a problem as long as load the bearings axially with a nut at either end?
Question 2 - Should I bother cutting a keyway into the plastic pully and threaded rod? Or can I simply thread in two machine screws through the pully hub?
Question 3 - I do not plan on using linear bearings. Instead I plan on having the 3/8" thompson rod slide directly through the 1" HDPE. Should this be a problem other than with long term wear and tear on the holes in the plastic?
Question 4 - Is it better to mount the lead screw A) directly between the slide rails, B) Opposite slide rail plane from part, C) Between slide rails and part?
Thanks for all your help!
