586,103 active members*
3,514 visitors online*
    Boss 6 servo upgrade
    Upgrading to ac servos on boss6 , going with leadshine ac servos 19mm shaft on servos, that are shorter than factory , just curious to see if anyone has dealt with this , not sure if we need to make 19 mm to 5/8 adapter to get length or find pulleys with long side of the timing belt just getting into this & this is the first hurdle of the conversion
    Re: Boss 6 servo upgrade
    Quote Originally Posted by fbcmachine View Post
    Maybe use a shaft coupling to connect?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Bridgeport Boss 1 CNC upgrade
    By Built in forum Bridgeport / Hardinge Mills
    Last Post: 01-25-2021, 02:21 AM
  2. Upgrade from BOSS 3
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2017, 07:52 PM
  3. Boss 5 upgrade
    By Tig-140 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2013, 04:08 AM
  4. Boss 5 Upgrade
    By Meenbombs in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2011, 04:00 AM
  5. Bridgeport Boss 3 upgrade
    By HawkJET in forum LinuxCNC (formerly EMC2)
    Last Post: 06-19-2010, 10:30 PM
