586,287 active members*
4,053 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Ma600 h2 draw bar replacement
    Oct 2023
    Hey I'm working on a ma600 h2 mc
    We had issues with tool being lose in spindle for the force was below 200 so I order new sprind and spacer. On disassemble I found there was nothing retaining the draw bar in the spindle like I'm use to seeing (cap, set screws, lock rings, ext.) I was able to pull out bar with little force. Now on reassemble I need to press the bar in 3.5 to 4.5 inch. In spindle and don't want this coming back out me when I let pressure off. Is this tapper locked or something or I'm I missing something big here any help be appreciated I'm new to working on okuma
    Mar 2009
    1982
    Re: Ma600 h2 draw bar replacement
    is the tool shank BT? What about clampng collet ( two "lips" holding the shank bolt ) ? With tool clamped and cylinder mounted there is no way fot the draw bar to jump out.
    If the design contains some fixing elements, it makes possible to take away the draw bar without hidraulic pressure.
    what kind of spindle is it? if its a 50taper you will need a special tool, if its hsk you will need to send spindle to okuma with with clamp/unclump unit to get it installed and set correctly,
  1. Draw bar
    By ivanjaramillo in forum Sharp CNC
    Last Post: 10-03-2017, 02:53 AM
  2. Replies: 1
    Last Post: 09-14-2016, 03:34 PM
  3. Draw Bar
    By g29cc in forum Novakon
    Last Post: 08-12-2010, 02:58 PM
  4. Draw bar tension
    By SIG in forum CNC Machining Centers
    Last Post: 12-04-2007, 05:18 AM
  5. MT's with a draw bar
    By lsfoils in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2003, 06:56 AM
