586,545 active members*
3,057 visitors online*
Thread: MC7 to 2022
    Sep 2007
    39
    MC7 to 2022
    Hello All,
    I just upgraded finally to 2022 two years ago. A lot of my files are MC7. Anyone know how to convert them so i can open them to use again? I do have access to X5 if that helps.
    Mike
    Dec 2008
    3110
    Re: MC7 to 2022
    I assume your MC7 is v7, not X7 (seeing that you also mention X5)
    It is a big gap, what.... 30 years?
    Newer Mcam files can only be converted (with paths) across 3 version levels (you would need to have those other versions installed on the PC to do it, so v7, v9, X5, X9, 2017, 2022 .... these are the steps you have to put the files thru.)
    Another way is to export in v7 as STEP/IGES etc, then import into a 2022 session... problem is no toolpaths will be transferred (that is that you have paid for the STEP converter in v7).
  1. MC7 to MCX-5 converter
    By Ecmdrw5 in forum Mastercam
    Last Post: 01-27-2024, 06:18 PM
  2. SAVE THE DATE - SolidCAM World 2022 Virtual Summit - May 11, 2022!
    By PeteRoy in forum Trade Shows / Webinars / Other Events
    Last Post: 01-23-2022, 06:07 PM
  3. MC7 manuals?
    By goodplastics in forum Mastercam
    Last Post: 07-25-2007, 03:06 AM
