587,019 active members*
5,763 visitors online*
Results 1 to 2 of 2
    Jun 2022
    58
    Cable Drag Chain
    I'm at a total loss now in this portion of my journey with the fabrication of my CNC and am seeking some reassurance in the direction I'm lost at...
    Let's talk Cable Drag Chain for a moment...
    The mfg. mentions to order the radius in increments of like 50/75/100/125/150
    Radius is what is confusing for me in this application...
    for conversation, If I order a 100mm Radius will this chain have a @3.93 diameter measurement or doubled since radius's are measured from the center to outside of the circle
    So, If I want 100 mm from the bottom of the chain to the bottom of the upper portion of the chain should I order a 50mm radius.?
    Paul
    Jan 2008
    1538
    Re: Cable Drag Chain
    https://www.igus.com/info/energy-cha...ble-carrier-ca
    https://dynatect.com/resources/how-t...cable-carrier/
    Bend radius may be the centre of the drag chain (not the inner or outer surface)
    IGUS have a good design tool, as do other drag chain manufacturers
  1. Drag Chain Router Cable
    By Project_Hopeless in forum DIY CNC Router Table Machines
    Last Post: 04-07-2020, 06:48 PM
  2. Drag Chain Cable Management
    By andrewwong2000 in forum Avid CNC
    Last Post: 03-21-2019, 03:34 PM
  3. File to make cable drag chain
    By Mike505 in forum MetalWork Discussion
    Last Post: 11-04-2015, 09:25 AM
  4. Plasma cable in drag chain?
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-20-2012, 07:58 PM
