586,113 active members*
3,429 visitors online*
    Jan 2024
    Mach2 "Start from here" not working (unregistered)
    I was wondering why the "start from here command isn't working, setting the line isn't working either, is this a feature exclusive to fully registered mach2?
    Nov 2013
    4376
    Re: Mach2 "Start from here" not working (unregistered)
    I use Mach4 and have done for 8.5 years, and Mach3 before that. The Run From Here (RFH) command does work but there is a procedure that you have to follow to the letter or it will crash.
    Its all about the preparatory move.....if you get that right you're OK. Misunderstand and CRASH!!!
    Its been so long since I used Mach3 RFH that I doubt I could advise you well.
    Mach4 is light years ahead.
    Craig
    Aug 2005
    1094
    Quote Originally Posted by SparkPy View Post
    There is no such thing as “fully registered “, it’s ether registered with a license or it’s not.
    It certainly works with a licensed version of Mach3
    Cheers
    Peter.
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. Profile Rail Wood Frame Router, 25" x 37" x 6" working area
    By jpvonoy in forum CNC Wood Router Project Log
    Last Post: 03-01-2019, 03:47 AM
  2. "Probe" and "Verify" not working - Mach3 & ESS
    By Mogal in forum SmoothStepper Motion Control
    Last Post: 03-17-2017, 07:05 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. CNC Scan CAD software "unregistered"
    By Boss&Sons LLC in forum Tormach Personal CNC Mill
    Last Post: 07-25-2012, 08:59 PM
  5. Mach2 bombs when I hit the "stop" button
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2005, 04:09 PM
