586,094 active members*
3,993 visitors online*
Results 1 to 19 of 19
    Sep 2016
    5
    Fusion360 Post Process
    Hello
    what Post Process use for planetcnc in Fusion360....??
    I use this below on Autodesk page.... but doesn't work ...bunch of errors an Q errors....
    Any suggestions???
    Dec 2019
    18
    Re: Fusion360 Post Process
    Quote Originally Posted by ZaraCNC View Post
    Hello
    Any suggestions???
    I've been using the reprap.cps on my Mk3/4 with TNG for 5 years with no issues.
    Sent from my SM-S908U1 using Tapatalk
    Feb 2011
    138
    I am using version 43323 with some adjustement, works perfect.
    May 2022
    20
    Hi there
    I’ll be able to help you edit the post so it works correctly with PlanetCNC.
    I specialise in developing post processors for fusion and it should be fairly straight forward to resolve. Please email me at [email protected]
    Michael
    Sep 2016
    5
    Quote Originally Posted by maki View Post
    Are you willing to send me your postprocess..?
    Feb 2024
    Set the smoothing in the post processor from G64 with PQ to G64
    Feb 2011
    138
    I can share but, be aware that there is some pin-out used which can be diferent than yours...
    Sep 2016
    5
    [email protected] moze na email....
    jer nemogu vam poslati privatnu poruku blokirali ste primanje
    Feb 2011
    138
    hmmm, I'll will check that
    and I did, nothing wrong or blocked. Did you recive my PM?
    Aug 2020
    131
    Get stock one from fusion works if you set the smoothing parameters right
    Sep 2016
    5
    Quote Originally Posted by ScorpionTDL View Post
    What do you mean by STOCK one?? can you link it? (i am soo new to all this , and learning Gcodes)
    Smoothing parameters??
    Sep 2016
    5
    Dobio sam email HVALA....
    Kad idem poslati PM tu na forumu ovo izbaci...
    The following errors occurred with your submission
    • maki has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
    Feb 2011
    138
    hm
    there must be something with server....
    I got this err when trying to modify my profile:
    403 No access
    There was an unexpected server error.
    Dec 2008
    41
    Same issue. I've to remove the line with "Q" command every time.
    Sep 2016
    5
    Quote Originally Posted by leomonti View Post
    Yes! same! i dot know how fix that....?
    Feb 2011
    138
    As I sad before, there is certain command that ONLY suits my cnc.
    "Q" "x" is an output which I use for my cnc, you need it or not....
    There is an option when generating nc file, check box wit dust suction and vacuum can be enable or disable. That generates lines with "Q" in.
    Hope it helps....
    Sep 2016
    5
    Hope it helps....
    No no , i wasn't telling about your custom post process....
    I am telling about on Autodesk page....there is always Q error and i dot know how to remove it ...........
    Feb 2011
    138
    Ok, sorry my mistake.
    I think that @ddrulez point you to proper thing. When making NC program, take a look to pull down menue where is written "G64 PQ..." something and CHANGE it to G64 ONLY.
    Attachment 501522
    Sep 2016
    5
    THANKS ALLOT !!!!
  1. Post processor for fusion360 to mach3 mill
    By Rustyj in forum Milling
    Last Post: 09-03-2020, 01:49 AM
  2. Fusion360 post
    By yugami in forum Milltronics
    Last Post: 04-15-2019, 09:36 AM
  3. Fusion360 post oddity
    Last Post: 09-15-2018, 09:02 PM
  4. Fusion360 for FADAL post Processor
    By Brooklyn1 in forum Autodesk Post Processors
    Last Post: 03-08-2016, 03:27 AM
  5. Newest PP Fusion360 post.
    By s2jesse in forum Tormach Slant Lathe
    Last Post: 02-28-2016, 04:17 PM
