586,242 active members*
3,624 visitors online*
    Feb 2024
    17
    Bit Naming On Star CNC's
    I'd like to be able to add comments to the PMC. Most importantly to the A addresses to make the alarms I've created actually tell operators about the status
    I've seen videos of people doing this on other fanuc machines But I cant find anything on any of Star's lineup. I Don't have access to any computer editing software But I've been able to make everything work from the MDI panel. I just need comments. Is anyone familiar with this process?
    I'm guessing the reason the edit button is missing from the symbol screen is because the PMC is running(?) When editing, I have just flipped K17.1 and K18.1 to 1, enabling Ladder editing. Which can seemingly be done just fine with the pmc running
    There are keep relays named "Programmer enable", "Edit enable", and "Allow PMC stop". However flipping any of them is useless as they all automatically go back to 0 after a short moment
    Is there another keep relay that I'm missing or is it a parameter or Data table thing?
    Thanks for anything! I find it odd that it's easier for me to alter machine functions than to name them
    Sent from my BE2029 using Tapatalk
    Dec 2009
    955
    Re: Bit Naming On Star CNC's
    Try it in emergency mode state or go in PMC menu and stop the PMC
    Feb 2024
    17
    ESP hasn't made a difference for me. I can post an image tomorrow of what I've assumed is the PMC menu, in case i'm looking in the wrong place. My guess, however. Is the problem with that screen is the "stop" button might be invisible. Just as the "edit" button is before i turn on K17.1 and K18.1.
    Feb 2024
    17
    Alright I'm one step closer to clarity. I found this rung detailing that F1.7 (Machine ready) needs to be off in order to allow PMC stop. I'd think there would be a Parameter regarding this strobe. Anyone with a clue?
    Edit:
    The K900 Keep relays to the right are non-changeable
    Feb 2024
    17
    Resolved. I simply added a keep relay to bypass F1.7 in this rung
    Now I have access to everything
  1. Star PU JR. Software Program Utility
    By cosmo2000 in forum CNC Swiss Screw Machines
    Last Post: 03-15-2018, 07:33 PM
  2. Bearing Naming Question
    By Alchemist29 in forum DIY CNC Router Table Machines
    Last Post: 03-06-2013, 03:25 AM
  3. Need help naming these chips
    By Luppy in forum MetalWork Discussion
    Last Post: 05-30-2012, 05:27 PM
  4. Request Help naming a part
    By Burnit0017 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2010, 09:05 PM
  5. A2100 file naming
    By kendo in forum Tree
    Last Post: 02-13-2009, 04:30 PM
