586,913 active members*
2,960 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > PlasmaCam DHC2 and design and control 3.11 Help
    Been running with an old eMachine and windows xp for almost two decades, and it finally took a crap. I’m wondering if I can use the same software on a new pc running windows ten or eleven, or if I’m going to be forced to buy new software as well as a new pc. Follow up, does anyone know if I can find an adapter for a parallel port to usb/hdmi or something more commonly found on new computers.
    Apr 2018
    135
    Re: PlasmaCam DHC2 and design and control 3.11 Help
    I don't have specific knowledge of PlasmaCam, but in general modern versions of Windows (64bit Windows) do not allow full control over the parallel port needed for CNC programs.
    I think you will be better off buying a used, functional PC running Windows XP.
    For example: https://www.ebay.com/itm/17616667472...3ABFBMyLP-grNj
    I have not done business with that particular Ebay vendor, but a review of his other items suggests he that offers multiple older PCs (more likely experienced at repair) and has a 100% feedback rating (I avoid vendors with feedback below 98% and look for 99% or better).
    Sep 2005
    1195
    hi,
    is it possible to use 64 bit using Pci Xpress serial parallel card to be used with parallel card cnc mach3 board st-v2 ?
    Sep 2005
    1195
    Attachment 501608
    specs:
    - 2 external RS-232 DB9 serial port.
    -1 external DB25 parallel port available.
  1. PlasmaCam Design Edge not cutting the whole design errors
    By shawnrl in forum Uncategorised CAM Discussion
    Last Post: 01-06-2021, 10:50 AM
  2. Replies: 2
    Last Post: 08-22-2019, 04:39 AM
  3. Replies: 4
    Last Post: 01-03-2014, 06:52 PM
  4. Selling My DHC2
    By BilletTed in forum PlasmaCam
    Last Post: 09-19-2013, 03:58 PM
  5. Replies: 1
    Last Post: 05-13-2012, 05:22 PM
