Hi Lars - Ensure you have clear access to the carriage bolts so they can be re-tightened or checked without pulling the machine apart. They can come loose and you don't want it to be a mission to get at them. One design rule I have is that all bolts and screws have to be accessible without them being buried. Learnt that one the hard way. Plus if you have a blind hole make it deep so you minimise the issue of bottoming a screw. Peter
re: car spacing - The rule is "as far apart as possible" A good arrangement is that they are square so if the rails are 200mm apart they are 200mm apart in the other direction. Obviously the further apart they are the less travel you have if your rail length is fixed. But a compromise has to be met...
