I made one out of a furnace blower motor and a few parts. Mounted the motor with it's shaft vertical and attached a large belt pulley to it. Attached to the pulley was a round piece of 3/4" plywood. The mold was sandwitched between a top piece of plywood and the one attached to the pulley with long bolts. The top piece of plywood had a hole thru it which the metal was poured thru as the mold spun, center sprue. You will have to experiment with how tight the mold is sandwitched. Tight enough to keep the metal in but loose enough to let the air escape.
CAUTION....... Use a splash ring around the spinning mold. If you miss with the molten metal, it WILL go flying. Ruined a set of blue jeans and have the scars on my shins to remind me.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
