586,329 active members*
4,866 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS TM1P air line inlet part — broken — need new one
    Hello, I have 2009 TM1P and noticed an air leaking near the inlet behind the machine. Found the leak from this grey aluminum cylinder looking part. Can anyone tell me what this part is? So I can order replacement. It looks like there is no adjusting knob so I guess it is just for distribution purpose? Can I just make my own distribution block and replace it? Thanks in advance.
    Re: HAAS TM1P air line inlet part — broken — need new one
    Quote Originally Posted by Craftman805 View Post
    Is there a label or name plate with detail model name and brand?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Quote Originally Posted by cncmakers001 View Post
    No name. I think it is a haas original part came with the machine.
    Aug 2009
    1573
    ...looks like its a water trap Part#58-2012 maybe.
    https://parts.haascnc.com/haasparts/...=&model=&year=
    Enjoy,
    DJ
    Dec 2008
    3111
    You have an air outlet & outlet at the top, & a drain line at the base. It appears to be a filter with a water separator.
    The item with the dial is a regulator, it seems to have a fill level gauge, so I suspect it is a air-oil lubricator.
    The 3rd item at rear (clear glass) looks like another regulator with a manual water drain.
  1. haas tm1p 2007 spindle air leak repair help
    By kudos in forum Haas Mills
    Last Post: 02-18-2024, 10:47 PM
  2. Replies: 2
    Last Post: 12-01-2013, 06:55 PM
  3. KMB1 - Air line / oil line purposes routing.
    By Bob La Londe in forum HURCO
    Last Post: 06-25-2012, 01:42 AM
  4. tm1p spindle air leak
    By timmydabull in forum Haas Mills
    Last Post: 08-15-2009, 07:40 AM
