586,306 active members*
3,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Clamping Pressure For 304 SS Tubing
    Feb 2024
    Hi, I have a job coming up where I need to machine some 304 Stainless tubing. The OD is 2.5" (64 mm), but I do not know offhand what the ID is. I have had no luck trying to find a chart or any useful information on what to limit clamping pressure to for tubing to prevent deformation. I was wondering if I could get some suggested pressures based on wall thickness. Currently we are using hard jaws, and I don't believe my boss wants to buy soft jaws specifically for this job. The machine is an ST-40 if that makes any difference.
    What pressure ranges should I go for the following wall thicknesses:
    0.125" (3.1 mm)
    0.25" (6.4 mm)
    0.375" (9.5 mm)
    0.5" (13 mm)
    Dec 2008
    3110
    Re: Clamping Pressure For 304 SS Tubing
    Make a stepped bung to fit in the end, and if the OD is not to be machined... make soft jaws to avoid damaging the finish
    You could also make a stepped bung with centre for a tailstock centre.
  1. solidcam post processor 4TH AXİS SİMULTANE...FANUC , MITSUBISHI , HAAS ...
    By solidcamtr in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-15-2018, 06:15 AM
  2. Lathe clamping pressure.
    By c.franks in forum Haas Mills
    Last Post: 12-22-2015, 08:28 PM
  3. .25" 304 SS tubing
    By harlen.shaw in forum North America RFQ's
    Last Post: 08-13-2012, 10:48 AM
  4. Bending 304 Full Hard Hypodermic Tubing
    By zrwhat in forum Bending, Forging, Extrusion...
    Last Post: 04-07-2011, 03:36 AM
  5. Clamping Pressure
    By Team Pierson in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-12-2007, 08:08 PM
