586,114 active members*
3,319 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Falcon 200 turret won't align
    Dec 2006
    242
    Hey guys, I've had this machine for about six years. It has run pretty good for me. Last week, the turret stopped aligning. I get a "Turret not rotating" alarm. But the turret does rotate about 5 positions before it times out. The alarm indicates a prox switch problem. I can get to the prox switch by the top solenoid and I see the one under the back cover. I don't know how to test them. I'm not sure how to get into Program ware and I wouldn't know which bit to look for. The two small springs that push the locking pin up are ok. Any help or likely remedy would be appreciated. I'm in Rochester Hills, Michigan. [email protected]
    Mar 2008
    285
    Re: Falcon 200 turret won't align
    You'll need to take a photo of the Duplomatic plate riveted to the tailstock (Centerline) of the Turret.
    It has the model number and serial number on it. I could be a Mechanical or Servo turret depending on the plate info.
    The machine originally came with a Duplomatic Manual in a clear plastic binder with a blue spine.
    Also on the machine serial plate is the Control Diagram print number; what is it? 9120xxxxyyy?
    Dec 2006
    242
    I'm attaching a photo of the turret nameplate. I'll look for the machine nameplate tonight. Thank you for your reply.
    Dec 2006
    242
    Duplomatic Turret model #BSA200-12/20-220/380-60L
    Cincinnati Control Diagram # 91203107
    Mar 2008
    285
    Here are documents for the BSA-200 turret. Macouser in Charlotte, NC was the distributor and service for these in the past.
    Hopefully you can figure something out and do not have to deal with them.
    If you have the 91203107 Control Machine wiring diagrams they may help. If not Bill Oehler at Fives (Cincinnati) Hebron Tech Support can sell them to you.
  1. Falcon 200 Help
    By H4zey66 in forum Cincinnati CNC
    Last Post: 10-26-2022, 02:49 AM
  2. Cincinnati falcon 200 help please
    By markaw in forum Cincinnati CNC
    Last Post: 04-14-2016, 02:57 PM
  3. falcon 200
    By CMmetals in forum Cincinnati CNC
    Last Post: 10-10-2013, 05:01 PM
  4. Need Chuck for a Falcon 200
    By flores2322 in forum Cincinnati CNC
    Last Post: 09-28-2011, 09:02 PM
  5. cincinnati milacron falcon 200
    By mustafaguler in forum Cincinnati CNC
    Last Post: 01-29-2011, 05:51 PM
