586,553 active members*
3,527 visitors online*
Results 1 to 9 of 9
    Apr 2007
    641
    Wiring the step motors
    I have the 495 oz package from keling, i have two motors for the gantry, one of these should go with the rotation inverted , how do I have to wire it? The two motors are wired to the same x axis?
    Luis
    Feb 2006
    1260
    I'm sure someone else can straighten you out on this. My understanding is, you have to have them wired in a master/slave arrangement using (2) stepper controllers.
    If it works.....Don't fix it!
    Jun 2003
    3312
    If you set it up via software, then the 2nd motor is setup as a slave to the X axis. In the software setup invert the dir pin on the setup.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Apr 2007
    641
    Thanks, but dont understand, I know i can change the rotation in the software, but one has to go backwards, then it should be wire inverted, isnt it?
    Feb 2006
    1260
    Quote Originally Posted by lamicron View Post
    My Steppers came pre wired with plugs on them. They were all wired the same. I changed direction in Mach3 ports & pins. When you changd direction in the software it esentially does the same thing. Reverses polarity.
    Apr 2007
    641
    Thanks millman, but I think I have to wire the 4th motor to the A input, isn't it?
    Attached Files Attached Files
    Jun 2003
    3312
    Yes wire the 4th axis as A. Setup the A ports and pins as wired. You will the control the rotation of the 4th axis in relation to the axis you slave it too. So you set the DIR pin of the A axis state to either low true or high true to get it to rotate the direction you need it verses the slaved axis. No motor wiring changes needed. Before you mechanically connect the slaved axis motors, do the software setup and test it.
    Feb 2006
    1260
    Quote Originally Posted by pminmo View Post
    Definitely Test the rotation! Even the 495 steppers especially through reduction could twist your gantry out of alignment. Or cause damage elswhere.
    Apr 2007
    641
    I received the same info from Zoltan, I'll go that way.
    Of course i'll try it before gear it..... i'm really scary about it!!!
    Thanks amigos!
  1. Step Motor Driver and Power Supply Wiring
    By mcan in forum Open Source Controller Boards
    Last Post: 01-19-2007, 11:22 AM
  2. I got the step motors so what's next
    By rbocaz in forum Waterjet General Topics
    Last Post: 08-14-2006, 05:04 PM
  3. Step-Syn Motors
    By lilwen in forum Stepper Motors / Drives
    Last Post: 07-03-2006, 03:17 AM
  4. Step sync motor wiring
    By sailinon in forum Stepper Motors / Drives
    Last Post: 11-12-2005, 07:17 AM
  5. Before buy the Step Motors.
    By samsagaz in forum Stepper Motors / Drives
    Last Post: 03-29-2005, 12:50 AM
