586,460 active members*
3,253 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Question about Leadshine DM556 Stepper Motor Driver
    Dec 2019
    4
    Hello, I'm new to forum (and Arduino) so I hope I'm asking this correctly.
    Does anyone have any advice/guidance for interfacing a UNO to a Leadshine DM556 driver?
    https://www.oyostepper.com/goods-124...per-Motor.html
    PDF:https://www.oyostepper.com/images/upload/File/DM556.pdf
    I'm planning to use a NEMA 34 motor to drive the Z-axis on small mill. No positioning, just want to control speed and direction.
    Regadrs,
    JD
    Dec 2012
    203
    Re: Question about Leadshine DM556 Stepper Motor Driver
    You can connect the UNO direct to the DM556.
    The DM556 has optocoupler inputs that will work direct connected to the UNO.
    connect the +5v of the uno to PULL + and DIR +
    connect any two digital outputs to PULL - and DIR -
    connect your motor and power supply to the DM556
    program the Arduino and go for it
  1. Replacing a Tormach 3-Phase stepper driver with a Leadshine driver
    By Titaniumboy in forum Tormach Personal CNC Mill
    Last Post: 02-10-2024, 11:15 AM
  2. Replies: 0
    Last Post: 04-27-2016, 10:05 AM
  3. Leadshine DM556 stepper motor driver.
    By Kingjamez in forum Stepper Motors / Drives
    Last Post: 08-02-2009, 03:22 PM
