586,112 active members*
3,101 visitors online*
    Jul 2005
    43
    TL-2 tool changer
    About to pull the trigger on a TL-2, not being a lathe guy I wanted to see others opinions on the tool changer. They wont sell the 8 tool changer on a machine with a tailstock but they will the 4. I feel like more often than not a person would need more than 4 tools but maybe I'm wrong. So my questions are: Is 4 tools enough most of the time? How hard is it to remove the tool changer and go to a manual tool post if needed (I did find a post via google searching of a guy doing this but didn't go into how much work it was). I have found a couple used 8 tool changers for sale, are they not that good?
    Re: TL-2 tool changer
    they used to sell the tl1 with a manual tool changer not sure about the tl2 . If the did or do then it shouldn't be hard to modify
    I used a tl1 a lot for prototyping and small runs and the 4 post accomplished what I needed to do . If your going to be using a few drills and taps then it's easy to make a bar that holds a few tools which only eats one tool changer position . That way you still have room for a partoff , turning and another tool if needed
  1. Haas Tool Changer making honking noise at end of tool change
    By kentdesautel13 in forum Haas Machines
    Last Post: 07-15-2022, 09:31 PM
  2. Adding new tool locations - tool changer M6start VB script editor in mach 3
    By demonx in forum Mach Wizards, Macros, & Addons
    Last Post: 12-23-2016, 06:20 AM
  3. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  4. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
