586,094 active members*
4,052 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Dual Shaft Stepper Motors Advantage
Results 1 to 16 of 16
    May 2009
    1332
    What is the reason to have stepper motors with dual shafts? Looking online there are not a lot with dual shafts
    Nicolas
    Aug 2005
    1094
    Quote Originally Posted by kolias View Post
    The main reason was to attach an encoder to the stepper on a handle for manual adjustment.
    Note that it should not be used as a drive shaft as the bearing at that ind is not up to it.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    May 2009
    1332
    Re: Dual Shaft Stepper Motors Advantage
    Quote Originally Posted by phomann View Post
    Note that it should not be used as a drive shaft as the bearing at that ind is not up to it. Cheers Peter
    Thanks Peter, looks like "steppersonline" is the best place so far to buy motors with digital drivers but when I asked about dual shafts he said No. I normally use dual shafts to attach a home made hand wheel for adjustments on the Y axis since I drive it slaved to A axis but I can manage without the hand wheel. I also asked if he can supply a BOB with a parallel port and he said No, so I will source the BOB from others.
    Nicolas
    Nov 2013
    4375
    it matters less where you buy than selecting the right ones. To many stepper are made with high inductance and are poor for CNC. The high inductance ones
    tend to have the highest torque, which is what attracts buyers and can be made cheaply. Low inductance steppers tend to have lower torque despite having higher current
    and be more expensive....but are hands down better than high inductance types.
    For 23/24 size stepper look for 1mH-2mH, 1mH preferred and reject anything over 2mH.
    For a 34 size stepper look for 2mH-4mH, 2mH preferred and reject anything over 4mH.
    Craig
    May 2009
    1332
    it matters less where you buy than selecting the right ones. To many stepper are made with high inductance and are poor for CNC. The high inductance ones tend to have the highest torque, which is what attracts buyers and can be made cheaply. Low inductance steppers tend to have lower torque despite having higher current and be more expensive....but are hands down better than high inductance types.
    For a 34 size stepper look for 2mH-4mH, 2mH preferred and reject anything over 4mH. Craig
    Many thanks Craig, I knew about the inductance property, for NEMA 23 what I get is 3.8mH the lowest but I will look again if I can find ones with a lower value. But I also think the motor driver should be "Digital" and the majority on the web they just say "Motor Driver".
    Nicolas
    Nov 2013
    4375
    That's not the worst I've seen but still double what you want. Keep looking, don't settle for anything over 3mH at the outside, and for my money I would not get anything over 2mH.
    Peter Homman responded to your post, and he sells steppers, including this one which is 570 oz.in and 2.1mH, would be a very good candidate.
    https://www.homanndesigns.com/index....30689e11p2fcm5
    They all are. Some are more sophisticated than others, but its small beer by comparison thre the stepper. Choose the driver with the highest possible in put voltage,
    I'd suggest no less than 80VDC.
    Craig
    May 2009
    1332
    What is "D-cut Shaft Length: 20mm" ? I dont understand the D-Cut what it means
    Nicolas
    Aug 2005
    1094
    It’s the “flat” that they put on the shaft for the set screw to fasten against.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    May 2009
    1332
    It’s the “flat” that they put on the shaft for the set screw to fasten against. Cheers Peter Sent from my iPhone using Tapatalk Pro
    I didn't know the "flat" is called D-Cut, thanks
    Nicolas
    May 2009
    1332
    Craig you are talking about 570 oz.in motors and 80VDC max drivers, all my previous machines had 280 oz.in motors and 50VDC max drivers and never had a problem moving my 3/8” thick aluminum gantry with a water cooled spindle. I just cant imagine where you will need anything more than what I used. I understand you are using your machines to cut steel/SS and perhaps in this case the numbers you mentioned are more appropriate, mine are designed for hobby/light commercial use.
    I also know about the “homanndesigns” wonderful site but he is in the “southern hemisphere” and shipping to “northern hemisphere” will be quite expensive.
    Nicolas
    Nicolas
    Nov 2013
    4375
    firstly the higher voltage is about speed WITHOUT missing steps. 50VDC is now entry level at best, do yourself a favour and get high voltage drivers, they cost but pennies
    more than lower voltage units so you might as well have them. If 280oz.in is good enough then carry on but if you ever start losing steps you'll think 'I should have spent and
    extra $10 and got those bigger ones'.
    Nicolas
    Ask him. Last week I had some Canadian dude saying that I (in New Zealand) was closer to China than he was......he was wrong...not much in it, but he is 500km closer than I am.
    Craig
    May 2009
    1332
    Hey Craig, I thought you will remember who I am, the “Canadian dude” is me, Forum name is “kolias” real name is Nicolas. You have helped me in the past a lot and I appreciate you knowledge.
    I haven’t purchased anything yet but looks like what I will buy is a “set” with no options to ask for any changes. I’m still looking and perhaps I may find a place which will give me a choice.
    Nicolas
    Nicolas
    Nov 2013
    4375
    yes I knew it was you....just trying not to rub it in.
    Recommend that you get 'good' steppers and drivers, they will last many years, the modest extra you would pay for good as opposed to average will be rewarded over and over again.
    Craig
    May 2009
    1332
    Hi Craig, from the attached picture which of the 2 stepper motors is better? The second one it says to wire "Bipolar (Parallel)".
    I know they are not big to your standards but for my needs they will do the job. Both cost the same and not sure I will buy them but for comparison I would like to know.
    Nicolas
    Attached Thumbnails Attached Thumbnails MOTORS SELECTION Screenshot 2024-03-01 024739.jpg
    Nicolas
    Nov 2013
    4375
    the 3.6mH one should be disregarded, its inductance is just too high.
    The second on with 2.2mH wired bipolar parallel is best, 2.2mH is fair, but only fair.
    Craig
    May 2009
    1332
    the 3.6mH one should be disregarded, its inductance is just too high. The second on with 2.2mH wired bipolar parallel is best, 2.2mH is fair, but only fair. Craig
    Thanks for your time Craig
    Nicolas
    Nicolas
  1. 3pcs NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motors
    By automationtechinc in forum For Sale Only
    Last Post: 09-22-2015, 07:29 PM
  2. 3pcs NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motors
    Last Post: 09-22-2015, 07:26 PM
  3. 3pcs NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motors
    Last Post: 09-22-2015, 07:11 PM
  4. 3pcs NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motors
    Last Post: 09-22-2015, 07:07 PM
  5. 3pcs NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motors
