587,047 active members*
2,503 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Servo in speed/ position mode for lathe.
    Nov 2011
    17
    I have just recieved a Chinese spindle in the mail. My lathe retrofit will use this as the spindle motor. I'm using mach 3 and a USB breakout board. The servo drive is a SDF20NK9X, and I am hoping someone can give me some tips on setting this thing up as a spindle motor ( in speed mode) and then switching to position mode with relays to Position mode. The instructions are quite vague. Thank you!
    Re: Servo in speed/ position mode for lathe.
    Quote Originally Posted by coltac View Post
    You can find this AC servo driver user manual at below page for your reference.
    https://www.paycnc.com/info/sdfxwe-s...v24_i2652.html
    Nov 2011
    17
    Thank you. I might be missing something but I don't see how to change the control mode. Any clue?
